Originally Posted by blykins
Remember, there's nothing really wrong with the throw out bearing touching the pressure plate. McLeod and RAM both say that's fine.
Centerforce doesn't want a preload on its TO Bearing -- if you call the tech guys they will tell you that. Coincidentally, I recetly ran across the service below having to do with a "Squeal-Like Sound Due To Incorrect Pre-Load On Clutch Throw-Out Bearing." Not an FE, not a TKO, not a Cobra, but interesting reading nonetheless.
http://project-jk.com/images/tsb/TSB_06-002-07.pdf
