Thread: TKO 600 noise
  #40 (permalink)
Old 06-17-2009, 02:37 PM
maxum_101 maxum_101 is offline
its been raining all day here so no chance in driving it to get it up to temp, i also called centerforce tech and they dont have any idea what i was talking about, about the air gap and if its ok that the throw out bearing spins all the time he just kept saying .. its up to the application,so no help there.
so i need to wait for a day with no rain,
elmariachi... so are you saying that there are throw out bearings that always spin?
also i hear alot about switching the tranny fluid over to some gm type fluid, anyone know what it is and how much oil the tko 600 takes. ?
when i let the car idel up to temp i still dont get any noise, it only comes when i drive it, so it must be the gear box and the oil thinning out when it gets hot, but how does one explain the noise going away when i press in the clutch?
as for the spring set up... i will be looking to get some springs and will need to fab up some brackets to be able to mount it nicely, dont want a hacker looking job, i guess having less pressure on the t/o bearing/ pressure plate wont hurt, i can press the fork back enough by hand to get that air gap, so i need to find a spring that is strong enough to pull it back.
thanks to all for posting,
i will post back new findings. i will try changing out the fluid first to see if that gets rid of the noise
