  #935 (permalink)
Old 06-17-2009, 09:15 PM
Double Venom's Avatar
Double Venom Double Venom is offline
abram,
The size is really a size of choice. I normally start at the front of the dash area with a 2" center stripe, the pin is 1/8th " wide with an 1/8" gap. The stripe starts out at 10.5"s and tapers to around 8 &1/2"s at the front of the cowl. The rear doesn't taper but a "little" and starts behind the back seats the same distance as I use for the start of the front-at the cowl.
I've gone as much as 11.5"s at the front cowl but always taper them down on the front to about 3"less than what I started with. Clear as mud?
DV
