There are a lot of ways to achieve the end results but increasing the air corrector size (raising the number) is by design intended to weaken the WOT mixture, and delay when the main system comes on line. The fuel jet/air corrector are going to impose a limit on WOT air fuel ratio. Any time the throttle is not on the floor the emulsion tube is involved heavily and the limits of the jets have not been reached. The small block race cars (with 40 or 42 MM venturis) reduced the air corrector in an effort to bring the main system on line quicker (exiting turns) with foot on floor and to richen the WOT mixture.
All things being equal, the use of a moderately agressive [b]Roller cam[b] cam on a given combination will allow the use of a smaller main jet because of a more abrupt pressure drop in the venturi during valve opening.
Rick
