Old 06-19-2009, 12:49 PM
cdnus cdnus is offline
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
Question Hydraulic brake light switch
I had my Hobbs brake switch blow a seal & leak fluid under pressure all over my left foot. Thanks for dual master cylinders, still had front brakes so I could drive it home, although somewhat carefully.
The only replacement switch I could locate in a hurry requires 60lbs.pressure to activate.
I would like to find one that comes in @ 2-3lbs & has a 1/8 npt. fitting, normally open, 2- wire connection.
What is everyone else using.
Thanks in advance for any help
Craig
