You close all the needle valves, and disconnect the linkage from the bellcrank, then get both sides to read as close as possible with the idle adjustment screws. Reconnect the linkage without changing the idle by ajusting the linkage bars. Then get both sides exactly the same with the needle valve adjustment. The end value is not important as long as they are all the same. Al
Al W.
