Old 06-20-2009, 05:45 PM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Smile
Originally Posted by Mus408 View Post
Noticed at the dragstrip,that the guys running the Dart blocks,are using the various Cleveland style heads. For street/strip use,up to 6000 RPM, are the power and torque gains that great over a 225 style TFS or AFR head?
For under 6000... No, but from there up to 9000+ yes they really start to turn the numbers, but if your going to try a stroker deal at those RPM you better buy a Big drip tray to stop the oil messing up the floor.
Part of the reason the LS heads 'look' so tall is the port enters the head at a steep angle so what you 'see' is not a true cross section area of the port, plus provision for the injector spray pattern is also made in the port casting at that point.
Jac Mac
