Old 11-21-2001, 10:25 PM
cobralee cobralee is offline
Hope you figured out your pedal pressure problem. If not, I had the same problem with my hydraulic clutch. It turned out that I didn't have my throwout bearing all the way in when installing it. So, after bleeding, it had no effect on the throwout bearing.
Otherwise, check to make sure you have the correct line as the bleeder as others have advised. I have a McLeod bearing and didn't need a vacuum to bleed it out, just a helper.
