The vin number is only to obvious the csx (wishing it was a Shelby) the 65(wishing it is a 65 model year)the 289 (does it have a small block?)and the sc( street/comp.)that was only to easy to figure that out but the strut front thats the big ? the front rotor has been redrilled ,what you might do is pull the wheel bearings and head for your local bearing supply and have them check the numbers they should be able to tell what they fit. good luck and include pictures of the body to some times that helps also.
