Thread: Hose Rub?
Old 06-22-2009, 02:47 PM
Nor Cal Al Nor Cal Al is offline
Cobra Make, Engine: Cobra-less
Default Hose Rub?
Noticed a small leak in the hose from the top of the coolant tank to the top of the radiator. Removed it to fix and found that where the tie wraps had been (coolant hose tied to overflow hose) the two areas were almost worn thourgh. Do not know if it is friction wear or chemical reaction of the hose materials.
You might want to check it out. I put tie wraps back on but turned them inward so the stem went in between the hoses and cut it off coming out the other side.
AL
Cobras Gone But Not Forgotten
