if your cap is on the pressure side (between block outlet and radiator core) the pressure will be more and you will see fluctuations in your water level if you don't have a can to catch the overflow and send it back when it cools, put on a 20+ cap and a hi flow thermostat and a catch can and your problems will go away. don't believe your expansion tank is the same as a recovery tank.
