Old 06-25-2009, 07:37 AM
Don Don is offline
The following was copied from a Real Estate listing in FL:
Garage Floor:
" 8-mil ply moisture barrier on 100-percent compacted lime rock. 6" concrete slab with No. 5 rebar and 6" O.C. each way, poured monolithic with a 12"x24" footer with four No.8 rebar continuous. "
" Floor Coating: Epoxy / Urethane System by Pro Painting of Hollywood, Florida : "
" The floor was steel shot-blasted to clean and abrade the surface to a profile similar to 80-grit sandpaper. This ensures proper adhesion of the new flooring system. Next, a penetrating epoxy sealer was applied. Then all cracks, voids, pinholes, and so on were patched with epoxy patching cement. Next, two coats of High Performance Epoxy were applied twenty-four hours apart, tinted a light tan color with a dry film thickness of 9 mil. This provides a smooth solid base for the finish coats. Then two coats of Aliphatic Urethane tinted the same light tan with a dry film thickness of 5 mil were applied 24 hours apart. The urethane is extremely durable and resistant to abrasion, chipping, and resistant to all automotive chemicals, fuels, and oils. High-gloss finish will not fade and cleans very easily, just mop or wipe. "
