Old 06-25-2009, 12:40 PM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
The assembly guy from B and B finally called. The designer of the arms advised the bolts can be just cranked down to pull the arms in or you can put equal spacers on each side. This is the newer front end that once the alignment is set stays better than the older design.
On the calipers, the pistons have a long enough stroke and spacers are not required.
