Old 06-26-2009, 12:16 PM
Rwillia4's Avatar
Rwillia4 Rwillia4 is offline
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
The other thing it might be is rubbing the spring. If it has happened a number of times you should be able to see the rub mark. If you can't get a dry-erase marker (like a green or red) and mark the inner fender lip area and the spring. Go for a "fun" drive and re-inspect to see where the marker has rubbed off.
Have you had your car 4-wheeled aligned?
