My jetting (which might not be ideal)...
347 stroker (302)
48 IDF carbs. (PS!)
CompCams FS 308-R10, cam Lift .613, Lobe sep. 110 deg.
40mm (40,5mm) chokes
4,5 aux. venturis
f11 emulsion tubes
165 main jets
190 airs
65 idle jets.
Pump bypass 000 (closed)
50 pump jet
Idle screws 3/4 out
By 7/6- 2011 (edit) I run:
4,5 aux. venturis
f11 emulsion tubes
140 main jets
190 airs
50 idle jets.
50 pump jet
Idle screws 1/2- 2 out (some of the fuel orirfices partially blocked?)
As a remark: I did several AFR test- runs last year with 150 main jet and got a little ritch readings on medium to high RPM's. Hopefully it has dropped down to ĀF around 13.0, I haven't tested yet.
Rune
