Old 06-29-2009, 08:41 AM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
Not sure what type of door you have, but if you have a sectional door and your garage ceiling height is tall enough you could add another section to the top. Then extend the roller tracks up and back. You may be able to even just extent the tacks without adding a section if when you redo the opener the pulling arm goes low enough. This would move the whole door higher when opened. You could do it yourself. If you have a garage door opener you would have to get an extention kit and move it further back to allow for the taller door.
Ask a garage door company to come out and give you a bid. They can look at your situation and then you can evaluate your options.
Wayne
