06-29-2009, 04:10 PM
Cobra Make, Engine: SPF#0760
Will it crank with jumper cables?
Another owner I just finished working with found corroded connections on the fuse panel under the dash...he had a similar problem to yours...strong battery but no cranking...
Sure the alarm system could be removed, you just need to re-attach all the wires where they belong...
SPFWiringDiagrams@Comcast.net
