Okiesnake,
Thanks for the pictures. I did hook up the
oil pressure line to the correct opening on the engine block. I am going to double check the flow direction through the
oil cooler first thing in the morning. I could be wrong, but I thought that I checked it according to Alan, at Unique, by removing the
oil temp sensor nut on top of the remote oil filter, (disconnecting the coil wire) and turning over the engine until oil ran out of the sensor port. I'll let you know about the lines when I check them in the AM. Thanks,
Fred
