Sounds electrical. Check the ignition switch. It sounds like when it is in the start position it has the ignition system powered up but when you release the key and it returns to the run position the ignition system loses power and you get no fire to the plugs. Alternatively, if you have a ballast resistor in the ignition primary side, you may have a loose connection on one of the wires connected the resistor.
Ken
