Thanks for the clarification. The proper pathforward for Superformance, is to only supply the polyurethane mounts. The proper path for any installer is to only supply the polyrethane mounts. The proper path for any individual installing their own engine and trans is to use polyurethane mounts. The 1972 olds delta 88 ruber town mounts are sheet and should have never been supplied with a superformance.
Originally Posted by RodgerH
Superformance supplies (with the car) a Small Parts Kit and one of 3 Engine Mounting Kits (small block, 460 big block, FE).
Dynamic has (had?) a parts/accessory company called Snakebite Performance that sold (optional...separate item listed on your invoice) a Install Package that contained just about everything to complete the car that was not included in the kits supplied from Superformance.
The engine mount pedestals were part of the Superformance Engine Mounting Kit, the actual mounts were part of the Snakebite Install Kit.
Your installer (not Dynamic, they don't do installs...they can only sell rollers, not completed cars) probably used what came in the Snakebite Install Kit (rubber mounts)....unless you specifically told him to use something different.
Rodger
