Old 06-30-2009, 05:27 PM
madmaxx madmaxx is offline
On the engine mounts i had to modify/cut the part that the bolts go through to utilize the polyurethane, this would indicate that superformance planned on the rubber mounts being used. Sure they will give you the lilne of sheet drill a hole and put a bolt and nut to limit movement. Give me a fuking break, if that is the case let the drill the hole and jerry rig the car mount like a junk yard special.
