Old 07-06-2009, 03:23 PM
patrickt patrickt is offline
Originally Posted by Doug I View Post
So that missing holds 1st, 3rd and 5th
The other bolt holds 2nd, 4th and reverse, and since it was loose that's why 2nd and 4th were so vague.
No, the shifter was just rotating/wiggling on that one bolt -- so it was only barely moving the shift linkage in the Tremec. It's a very, very simple little repair. But, just like last year, a loose bolt just about stopped me in my tracks. And this bolt (kind of like the set screw last year) would not be ordinarily seen unless you look for it.
EDIT -- For some reason, it just seemed to move "back" a little better than it moved "forward." That's the only reason I got 2, 4, and reverse.
