Next time it's hot and starts hard I'd do this. Retard your timing( you can pull and ground the coil wire as a way to do the same test), see if that helps. If it doesn't than you'll have narrowed down the list of possible causes. If it is the problem, check your timing, and then consider using a retarder if you feel it's needed. But first I would suggest that you check/clean (even if they look clean) all connections from the battery to the starter. If you are running a solenoid, other than the one on the starter(most minis have thier own), eliminate or at least insulate it. If this is a new problem on a new motor or starter, check for proper starter installation(does it need to be shimmed to stop binding with the flywheel). If all else fails, have your battery and starter tested. High performance applications die young and sometimes even new parts start out bad. Bottom line is what some of the other guys are telling you, their motors start fine and yours should to.
Bill
