  #38 (permalink)
Old 07-09-2009, 06:18 PM
blykins blykins is offline
Ahh, I see, so the offset coil springs kind of push your shifter over for third gear so it's easier to find, correct?
EDIT -- Here's a youtube video on the Steeda Tri-Ax http://www.youtube.com/watch?v=g4sKE0u9efk
Patrick, yes.
It's spring loaded, so when you're going from 2nd to 3rd, you essentially just have to push upwards and the springs kick you over to the neutral position and you just continue to push up. When you get used to it, you're basically just shoving the thing upwards.
Rodknock...
You can use that shifter handle, or you can use the existing one that bolts to a regular Tremec shifter. A 427/289 Tremec repop handle will work.
Everyone....
I sell aluminum flywheels too.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
