  #46 (permalink)
Old 07-09-2009, 11:25 PM
RodKnock's Avatar
RodKnock RodKnock is offline
Rodknock...
You can use that shifter handle, or you can use the existing one that bolts to a regular Tremec shifter. A 427/289 Tremec repop handle will work.
Is the Tri-Ax that much better than the shifter that comes from Tremec? If I bolt my existing Kirkham-supplied handle to the Tri-Ax, then is the spring-loaded 3rd seem strange since the Kirkham-supplied handle is bent forward like the original 427 versus a modern straight up position?
I haven't done it, but I assume the switch of shifter mechanisms be done from "up top" in the interior.
Interesting. Sorry Tim for derailing your thread.
