Old 07-12-2009, 05:50 AM
jams's Avatar
jams jams is offline
Cobra Make, Engine: B & B
Could be a bad header tube. I had to send back my set years back because one pipe was bent wrong and I could not screw in one spark plug.
I don't know if there is a minimum distance away from fiberglass but the further the better. If you have concerns add some heat shielding.
How far are you away from the fiberglass now?
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
