Thread: V-Belts
Old 07-12-2009, 06:16 PM
Philm's Avatar
Philm Philm is offline
Geat looking stuff.
Be sure to check the rotation of the water pump, most last model 5lrs have them running in reverse.
A goo way to check is if the pump pully is smooth and the back of the serpentine belt contacted the pulley then it is a reverse pump.
You will need to change the timing cover as well as the pump if you go this way.
Phil
