Old 07-14-2009, 03:15 AM
Default Bill have you looked into small fans
WildBill3 Bill have you looked into runn small electric fans? They sell them in 3 and 4" size, draw about 7-8 amps and flow in the 220-280 cfm range. The boating world sell them for about 22-25.00 dollars. A relay and switch is all you need. 1 hose will work great to each side of the rear brakes or front brakes. If it's front brakes, can you pull air from the radiator outlet or small ducts under the nose of the car. Think like nascar for roadracing setups with all the hoses and fans, just less will do the same job. Rick L.
