3/8" thin wall radiator overflow hose slit lengthwise and then fit around the opening, windshield washer hose may work also, depending if body is glass or aluminum (body thickness). I did this for a grommet on the decklid for fuel filler cap. Cut the ends straight and use a little super glue to secure the ends together after fitting for length, works good.
Rick
