07-16-2009, 05:28 PM
Cobra Make, Engine: SPF#0760
Remember to also check your shock bushings for signs of crushing. Especially on the older AVO shocks (yellow). Confirm that the steel hoop that surrounds the shock bushing "is not" and "has not" rubbed against the lower rear control arm. Inspect the hoop for cracks, etc. I believe Energy Suspensions makes an acceptable replacement Poly bushing for the shock. The Bilsteins are designed different.
SPFWiringDiagrams@Comcast.net
