Originally Posted by SunDude
Thanks guys.
The brackets on my car do not show signs of distortion/twisting, but are just canted slightly upward from 90 degrees suggesting that the problem is only just beginning to form. Nonetheless I think I will order the replacement brackets and have them installed as soon as I'm able. Better safe than sorry.
I agree with Doug that, since this is basically a design flaw, Superformance LLC should provide owners with some type of upgrade kit or compensation as a goodwill gesture. I realize this would cost a lot; however, it might be a small price to pay to maintain their product's excellent reputation and value in the marketplace.
Superformance has a technical bulletin about this issue. If your brackets are OK, it basically says you can replace the bolts with proper bolts and you are done. Cheap and easy. No big deal. Since that seems to be your situation, go for it if you like.
The brackets which you can purchase are truly magnificent works of art. They are a great, reasonably priced upgrade to your car should you choose to go with them.
Jack
