Looks like the moderator of the Forum has changed the Image Aspect for
up-loads. Unfortunately I'll just have to go with this new concept. Probably something to do with either Climate Change or the Global Recession. If you want to enlarge these images, just double click on them. Oops. I have inadvertantly devolved some sensitive intelligence. Sorry ASIO. Hope I haven't stuffed up the 'Climate Change' propoganda. If there are any Inuet Eskimos in Barrow, Alaska, monitoring this thread, disregard my last comments. Sorry Mr. Rudd. It won't happen again.
Now that I'm back in favour, let's discuss this thread.
For my trim, I selected Connolly Leather and English Wilton Carpet embroided around the edges with Dark Brown Leather.
Thought I'd throw in a few pics of how my trim job is progressing. Should be out of the trimmers in about 5 days.
The carpets are down as well as the floor mats. Waiting for the door trims and heel pads on the floor mats to be finished.
I have selected leather behind the seats. A 50mm Cobra Bonnet/Boot badge will be inserted in the centre of thast circle in the centre and behind the seats.
Notice the 50 amp Anderson Plug attached to the left wall of the boot area which is where the jumper leads plug in. This negates having to crawl up into the bowels of the boot to connect the leads onto the battery. There will also be a permanent battery charging connection fitted nearby. The Cobra Snake and words 'COBRA' badge will be mounted in the centre, half way up the vertcal wall of the boot partition.
There are three separate compartments in my boot area. The first is at the rear left where the Odyssey Battery is located. There is additional padded storage in this area. It is partioned off to the right by another separate storage area and articles placed herein are secured therein by a 40mm lip on the front cover. Then there is the main boot area with the 75 litre fuel tank under the floor. It has additional storage inside either mudguard behind the rear light.
This area is separated from the rest of the boot area by a removable upholsteredl lid and as mentioned earlier, has additional storage space around the battery..
Baz
