Old 11-26-2001, 10:43 AM
niles niles is offline
Cobra Make, Engine: Hunter #28; 396 Cleveland stroker; more than 495 HP; TKO 5 speed
Default MOUNTS
I liked 427Sharps idea of using regular rubber mounts, while limiting the deflection with a C8 bolts thru the middle of the mount.
I drilled mine through (3\8) but added an improvement; under the washer on the limiting bolt; I fabricated a tough reinforced rubber waher out of the side wall of a tire. Put these with less clearance; approx 1\8 in; now the mount and deflect an eight and not hit the bolt metal to metal; but rather bottom on the rubber washer.
gn
