Old 07-25-2009, 09:25 AM
Cashburn's Avatar
Cashburn Cashburn is offline
Backdraft Racing Dealer
That is a really cool setup. Different for sure. You are going to have a bit of a headache though with the CT registration requirements, if the inspectors decided to dig in, may have to wait until October 1st for the new rules to take effect.
See: http://www.ct.gov/dmv/cwp/view.asp?a=804&Q=244898
As it is written (see the problem here):
Effective August 1, 2008 all composite vehicles (except motorcycles) presented for a composite inspection will be required to be equipped with the following emissions systems based on the year of manufacture of the engine used in construction.
Emissions controls must match the year of the engine used in the composite vehicle. Documented proof of engine year must be provided by the applicant. This information will be verified for accuracy and the presence of all required components will be verified during the inspection.
Note: This requirement will not apply to vehicles with engines purchased prior to August 1, 2008. Documented proof of engine year and purchase date must still be provided at time of inspection.
All Light Duty Vehicles with Gasoline Engines were equipped with the controls indicated below (Lt. Duty = below 6001 lbs GVWR till 1978 & below 8501 lbs GVWR after):
Year of Engine Emissions Controls Required of All Vehicles That Year
Pre - 1966 None
1966 - 1970 PCV, Variable Advance Distributor
1971 – 1978 PCV, Variable Advance Distributor, Evap. Canister, and Thermostatic Air Cleaner or Air Injection System
1979 – 1988 PCV, Variable Advance Distributor, Evap. Canister, Thermostatic Air Cleaner or Air Injection System, and CAT
1989 – 1995 PCV, Variable Advance Distributor, Evap. Canister, CAT, Computerized Engine Management, O2 sensor
1996 – current PCV, Electronic Spark Control, Evap. Canister, CAT, Closed Loop Computerized Engine Management, O2 sensors, Fuel Injection
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
