  #11381 (permalink)
Old 07-26-2009, 07:17 AM
4RE KLR's Avatar
4RE KLR 4RE KLR is offline
As for the golf cart.
Apparently the difference is the "deep cycle" rating on the batteries. The Trojans are rated a little different than the ones at Auto Zone.
The ones at Auto Zone have:
Cold cranking amps: 575
Cranking amps: 715
Reserve capacity: 160
The Trojans have:
The T105 is rated at 225 A/H and will deep cycle 300 - 500 times.
Dimensions inches (mm) (same as above battery)
L W H
10 3/8
(264) 7 1/8
(181) 10 11/16
(272)
Capacity Minutes Cranking
Performance 5 Hr
Rate AH 20 Hr
Rate AH Voltage Terminal
@25
Amps @56
Amps @75
Amps CCA @0°F CA
@32°F
447 - 115 - - 185 225 6 LPT, HPT, AP
Can anyone explain the difference to me in the two? And if the ones at Auto Zone will work?
