  #11392 (permalink)
Old 07-27-2009, 08:00 AM
4RE KLR's Avatar
4RE KLR 4RE KLR is offline
Originally Posted by 4RE KLR View Post
As for the golf cart.
Apparently the difference is the "deep cycle" rating on the batteries. The Trojans are rated a little different than the ones at Auto Zone.
The ones at Auto Zone have:
Cold cranking amps: 575
Cranking amps: 715
Reserve capacity: 160
The Trojans have:
The T105 is rated at 225 A/H and will deep cycle 300 - 500 times.
Dimensions inches (mm) (same as above battery)
L W H
10 3/8
(264) 7 1/8
(181) 10 11/16
(272)
Capacity Minutes Cranking
Performance 5 Hr
Rate AH 20 Hr
Rate AH Voltage Terminal
@25
Amps @56
Amps @75
Amps CCA @0°F CA
@32°F
447 - 115 - - 185 225 6 LPT, HPT, AP
Can anyone explain the difference to me in the two? And if the ones at Auto Zone will work?
I really do not know the difference in these and do not know if they will even work. I would hate to buy 6 -6 volt batteries that will not work.That would suck!
