  #11399 (permalink)
Old 07-27-2009, 10:02 AM
Joe Wicked's Avatar
Joe Wicked Joe Wicked is offline
Originally Posted by 4RE KLR View Post
I really do not know the difference in these and do not know if they will even work. I would hate to buy 6 -6 volt batteries that will not work.That would suck!
Steve, the reason those specs seem so much different is the Trojans are giving you Cranking amps like you would normally see in a car battery and the others are giving you Amp Hours. Cranking amps gives you the amount of juice you get at an instant (turning starter is more important on a car). Amp Hours gives you the time the battery will last at a specific load. (More important that initial start up power on battery powered carts). Both are a measure of the batteries power, but I would be more concerned with comparing the Amp Hours between the two.
Why do they call it "Common Sense" when it is so rare?
