  #11401 (permalink)
Old 07-27-2009, 11:05 AM
4RE KLR's Avatar
4RE KLR 4RE KLR is offline
Originally Posted by Joe Wicked View Post
Steve, the reason those specs seem so much different is the Trojans are giving you Cranking amps like you would normally see in a car battery and the others are giving you Amp Hours. Cranking amps gives you the amount of juice you get at an instant (turning starter is more important on a car). Amp Hours gives you the time the battery will last at a specific load. (More important that initial start up power on battery powered carts). Both are a measure of the batteries power, but I would be more concerned with comparing the Amp Hours between the two.
How do I get that information on the Auto Zone Batteries?
I see it on the Trojans, but I don't see that info on the AZ batteries.
