Suggestion
olddog Try and find one of the companies that cleans and flows the injectors to match each other. There is a 5-7% fudge factor for high to low injectors on most. Mine where matched back in 97 buy a pirvate guy who has passed on. Try over on the 5.0 club for this. The ohms reading will change when ampage is applied to them. The test we have is a 30 second pulse test for the coil inside. The other way is a flow check into beckers and read the CC after 30 seconds with a steady fluid source for the readings. 45 psi. I will look and see if I can find a company for cleaning. Rick L.
