Thanks RIck.
I have found one source (rcommended by a friend who uses them). They do not attempt to match the injector flows. By the time you pay shipping it will approach $150. I can buy new injectors for $280 - $330 depending on size.
I have 36 lb/hr now. My 347 might make 400-450 hp at the crank on an engine dyno, if tuned to perfection, but we all know it isn't going to get there in the car. Bottom line I think 32 lb/hr is plenty big enough and 30 lb/hr might be enough. So do I want to buy a new set.
Also I couldn't see a battery cable sized ground going to the engine. I have to get under it and make certain, but I don't think there is an adaquate ground on the engine. I'm wondering if the ground may be causing some of my problems. I want to get a good ground on it and see if that makes a differance.
Anyone ever clean there own injectors?
