  #1004 (permalink)
Old 07-28-2009, 08:09 PM
jimhurtt jimhurtt is offline
Cobra Make, Engine: 91, 65 CR 427 289 or 302
Thanks DV for taking the time out to detail the trunk rod mounting. It will enable me to mount it with less guess work. One other question that may seem a bit lame but where does the sending unit for the engine temperature gauge go? Before or after the thermostat? Mine is mounted in the water neck between the thermostat and the radiator so it is measuring the water temperature through the top radiator hose after the thermostat has opened. Is that right?
Thanks.
jim hurtt
