Originally Posted by Leeroy
I put the Moroso 3.5qt unit in mine as well with no solenoid. Works fine but if you get a solenoid type it will maintain pressure in the accumulator which then allows pre-lub before you start engine.
With my type the oil pressure equalizes throughout oil system when engine if off as the pressure is not trapped in accum. because no solenoid to close accum. outlet to engine etc.
Leeroy
I use a Moroso 3.5 qt unit with a manual ball shut off valve; give the handle a quarter turn to maintain pressure before shutting off the engine.
Turn handle quarter turn release pressure for pre-lube before starting the engine, and start engine.
Not as convenient as solenod.
