07-29-2009, 12:24 PM
IL
Cobra Make, Engine: Everett-Morrison, 434 cid
Originally Posted by Xavier
But I have been reading else where stating that solid motor mounts must have a solid trans mount, the twisting of the trans mount, however slight, will eventually cause the trans case to fatigue and crack, which did make sense to me. If the engine stays still, and the trans moves, eventually something is going to give. That did make sense, although I never heard of anyone using them.
In short, I have been second guessing myself and needed a little reassurance that this indeed is not for everyone, but is hardly a bad thing. Getting more launch to the rear wheels is just a bonus.
The motor and trans are one unit- solidly connected to each other. Solid motor mounts AND a solid trans mount will cause the engine/trans unit to become a stressed member of the chassis- the trans case is not up to the task. By using a urethane trans mount the trans is no longer a stressed member, now the mount will absorb chassis twist- an amount which is significant.
Scott
