David,
Do your mounts have the same dimension frame to top mount surface as original FE mounts? Cris from Kinetics told me that you guys mount your engines a little higher than originals, do you accomplish that at the frame cradle or the mount? You have a very well designed part that I would be interested in installing if the dimensions are identical to original mounts.
Originally Posted by David Kirkham
Our billet FE motor mounts are $295. (They come with the purchase of a roller.)
We make them in 2 pieces which makes it much easier to install the motor. Just line up the bolts in the holes and drop in the motor. They are also designed so they can not "break" and have the motor torque over and slam the side pipes into the body...no fun on the original cars. We have a cross bolt going all the way through them to prevent such mishaps.
We use urethane bushings to keep the vibrations down.
David
