Old 07-30-2009, 12:48 PM
franklin's Avatar
franklin franklin is offline
Cobra Make, Engine: Polished KMP #488 / 427SC, 427 SO/482 by KC
I also have the standard Holley Electric pump and have a union fitting where a mechanical pump could go at some point. I am running the same as above with the Mallory Regulator and the return line. I also have the same 482/427 side oiler you are running. My fuel pressure is also set at 5lbs.
Hope that helps,
Todd
