Old 07-31-2009, 10:01 PM
Gav's Avatar
Gav Gav is offline
How high is your roof?
If it is 4m or more you might want to look at discharge lighting (high bays or low bays). They give a much more 'true' light which makes life sooo much easier when working on fiddly things.
I would think one 15amp outlet near a bench would be enough, and 10 amp everywhere else.
I have leads strung up on a wire running the length of the shed which keeps leads off the floor and they can be pulled across to where ever you are working.
I would think that unless you are planning to run a full workshop that a 32 amp 1ph supply would be heaps, but if you have 3 ph run to the house I would recommend that you at least run 3ph cabling to the shed even if you don't use it. It will add value if you want to sell.
Powered by Cu
