Old 07-31-2009, 11:34 PM
Bob Broberg SPF667 460BB Bob Broberg SPF667 460BB is offline
First, check your tire pressure. Should be 20 to 24 lbs. With your hp ANY street tire will be like that. Next, 90 degrees C (194 F) is still normal. It took a long time to get mine to run at 80C (176F). On track days mine would get to 100 C but would lower if I didn't run high rpm all the time. You should have a 19 lb or higher radiator cap if you go up to 105. I know an SPF with a 514 that has run at 90 degrees for 50K miles just fine.
AZ Bob
