Air locks can be resolved by burping your motor or running it for 20-30 seconds then topping off the coolant. Once the rad cap is mounted the air remains trapped. When I refill a drained motor I remove the temp. swith or other intake plug . Air escapes from the block as you are filling with coolant at the rad cap. You can feel it escaping. Just add coolant slowly as the plug hole can quickly overflow since the rad cap is usually at a higher level.
