Old 08-01-2009, 05:45 PM
patrickt patrickt is offline
Originally Posted by Fastz06 View Post
Can I test the resistance of the ammeter?
That won't tell you what you want to know. I'm going to assume that your ammeter is not reading +100 the whole time you're running. If you were to put an ohm meter across your ammeter the resistance is going to be zero even if it is acting "like a skinny little wire" when really it should be "a reasonably fat wire." If you were to test it, you would need to put a measured load (watts) in a circuit along with the ammeter and your measured voltage. That's a PITA. What I would do is check the connections on your wire and, assuming you don't find anything loose or wiggly, put a ten gauge jumper wire securely across the terminals of your ammeter -- that will effectively negate your ammeter. If your wire heating problems then disappear, replace your ammeter. Make sense?
