Although you are a little limited to sensor locations or accurate pick up points the heater pick up points are many. You can get creative with T's and parallel lines since all you want is hot coolant.
A side note from earlier post, remember to add anti-rust or corrosion additives to eliminate electrolysis problems and get seal/lube agents.
